timing question
Old Oct 31, 2005 | 01:20 PM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
timing question
Okay just did a motor swap and started the engine timing by ear. It sounds smooth and has a good idle, but when I unplug the EST connector, the engine dies and won't run with it disconected. I did get a new chip and wonder if this is the problem. Is there another way I can set the timing. At idle ~1000 rpm with the connector connected, the gun read ~8* or so advanced. Suggestions appreciated.
Thanks,
Jim
1991 Pontiac Trans Am
383 TPI
Old Oct 31, 2005 | 01:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You have to unplug the EST before you set the base timing.
Off the shelf chips aren't exactly smiled upon around here...
Old Oct 31, 2005 | 10:19 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Well, I'm no good at setting the timing by ear, but I don't have any trouble starting my 388 with the STC disconnected and the #1 at it's DTC compression stroke and setting it with a timing light to 8°.
I set the base timing in the ECM first then the engine, run it for while and see what it likes, 8° seems to be the magic number for my engine.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
