reusing head bolts, how many times before it is a problem?
Old Nov 24, 2001 | 12:13 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I remeber reading somewhere that it is not a good idea to reuse your head bolts too many times. I know these heads have been takin off atleast 2 times, but the bolts look fine. Should I even worry about it?
Old Nov 24, 2001 | 12:24 AM
breathment's Avatar
depends on the type of bolt, there are some that will be unreusable the first time u torque them down. while others WILL work longer but its probably not good.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 24, 2001 | 12:27 AM
93ND500's Avatar
You can get away with using them over on stock rebuilds. I would change them if I were doing a performance rebuild, i.e. increased compression. They are not that expensive unless you go with the moly 12 point heads or studs.
Old Nov 24, 2001 | 06:25 AM
ede's Avatar
ede
SBC head bolts are reuseable and don't have a limit on the number of times they can be used. a lot of newer engines come with torque to yeild head bolts. they're torqued to the yeild point for maximun holding and are not reused. the yeild point is where the metal stretches and if it goes more it deforms, or breaks, at the yeild point it would return to "normal". you can tell a torque to yeild bolt by a torque spec like 45 ft/lbs + 25* or 45 ft/lbs and a 1/4 turn more.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 24, 2001 | 11:31 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
cool, that was what I was getting confused with. This is a stock rebuild, so if anything I will be loseing a little compression for the lack of carbon everywhere. Thanks for the advice
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
