tapping under egr on intake
Old Nov 3, 2005 | 08:13 AM
curtis84ta's Avatar
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
i have a constant tapping under my egr valve on my intake, it goes up and down with the rpm of the engine. ive tried adjusting serveral times the rockers but to no avail, is there a specific gap or compression of each spring at TDC? or is there a special way to adjust rockers exonly an example)with 1 at TDC adjust 1,3,6,8 then turn crank and adjust 2,4,5,7 with 2 TDC. and i have tried several times the spin the rod until you feel just a slight amount of resistance, then another turn 3/4, then tried 1/4 and 1/2 still the same happend. i had removed everything from intake, header (left side only), head, rockers, pushrods, but did not remove the valve springs nor did i touch them. i also put the rods in the same order they came out as well as rockers.
Old Nov 3, 2005 | 08:56 AM
curtis84ta's Avatar
any help would be appreciated. or anything that it could potentially be...
Old Nov 5, 2005 | 10:21 AM
curtis84ta's Avatar
noone know what it could be?
Old Nov 9, 2005 | 12:28 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
adjust them while the engine on. 1/2 turn after they stop ticking.
Old Nov 15, 2005 | 08:05 AM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
I have the same sound. I think maybe it's an injector.
Is yours really loud? Mine sounds like a light rocker tap. Maybe the EGR valve.
Old Nov 15, 2005 | 09:44 AM
curtis84ta's Avatar
it was a rocker that was loose it was really loud (my car is carb'd)
db057
Apr 28, 2019 07:45 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
dimented24x7
Sep 6, 2015 03:51 PM
rjcme
Sep 5, 2015 01:23 PM
