power steering brackets?!
Old Nov 4, 2005 | 04:21 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Ok, I went to the junk yard and picked up a p/s pump with the brackets on it, but when I get home, they dont seem to fit at all and the pump doesnt match my pump. So, can someone please send a photo of the darn p/s brackets so I know what they look like. Is there a cheaper method then going to GM and paying $80? I spent $12 already on these abortion brackets...
Old Nov 4, 2005 | 04:32 PM
Car: 88 Camaro
Engine: 310 LG4
OR, what other car can I get the brackets from that will work on my 85 305 blck?
Old Nov 4, 2005 | 09:43 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
What kind of car did you get it off . I may have something around from an 79 Impala . I know it looket the same but did not try . I would say any 305 from 85 will work with the same options as yours . What happen to yours ?
Old Nov 5, 2005 | 10:32 AM
Car: 88 Camaro
Engine: 310 LG4
Was a donor car, pulled motor, stripped it and chucked the rest. I got the brackets from under a 3rd gen, it was laying on the ground under the engine bay. There was a V8 block sitting in the engine bay, so i made an assumption. But, i doubt that motor was the orig, it had mis matched pistons lol!.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
