kill all radiators
Old Nov 24, 2001 | 07:23 PM
ss-Sleipnir's Avatar
kill all radiators
ok, i just bought me a new radiator, wel i got everything tightened down, and the two transmission lines, they tightened as far as me and my brother could tighten them, but now when i start it up, the top line, next to the hose where the coolant dump tank connects is just dumping it out, just as if it were hangin free, also now my fan wont come on, GRRR kill the damn radiators, just put a bucket of ice water there. anyone got any clues? its not really leaking from the bolt part, it LOOKS like its coming from the radiator mounting. and i did plug the battery back in, and i did plug in the fan, its an electric fan thanks!!!
305 92 Camaro RS, ttops
automatic, summit open element, my camaros name is Pig.
[This message has been edited by ss-Sleipnir (edited November 24, 2001).]
Old Nov 24, 2001 | 07:30 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
<font face="Verdana, Arial" size="2">Originally posted by ss-Sleipnir:
</font>
Sound like you have the same problem as I had with my transmission. The tranny lines have a little flare at the end of them and require a "seat" to sit against so they don't leak. Your radiator probably doesn't have a "Seat" in it... it just goes straight through. You have to buy adapters that screw into the radiator and provide a "seat" for the tranny line to sit against so it doesn't leak.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
Old Nov 25, 2001 | 03:42 PM
ok i figured out it was just pre-stripped, yeah, i let my brother tightenen that one, but still, does anyone know why when i test drove it, the fan didnt come on one time??? thanks
Old Nov 26, 2001 | 09:14 AM
Xenodrgn's Avatar
1)It's cold outside
2)Your engine is in good tune
3)You've got an Al radiator that cools very well.
4)You've got a with the wiring/switch.
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
