Questions after my gauge cluster swap
Old Nov 26, 2001 | 07:51 PM
un4givin89's Avatar
So I've successfully install my gauge cluster, it works, kinda. THe speedo is fine, had the car cilabrated today. But there are two things bugging me, the temp gauge keeps saying my car is gonna blow up when in fact its cool, and the tach seems 1000 over. I'm wondering if maybe this is becuase I have a 305 with the orginal 110 speedo and I put the speedo off a 350 with the 145 speedo. Maybe the tach and tempure are set differently cuase of engine size and power out put??
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
Old Nov 26, 2001 | 08:57 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
Try using your original plastic surround case. Take the new gauges (speedo, temp, tack, volts, fuel) and place them in your old casing. This worked for me going from an '89 to '84(with the 85mph speedo).
good luck,
Craig
84 Z28 305HO, 5spd, 222,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter, 14.630 at 93.17mph
Del-A-lum front control arm bushings, Moog ball-joints, Energy suspension front sway bar end links, Moog rear sway bar end links, Eibach pro-kit springs, tokico shocks/struts, AU secondary rods
www.indycamaro.com
Old Nov 26, 2001 | 10:08 PM
Enkil's Avatar
The temperature gauge shooting all the way up like that means it's either grounded where it shoudln't be, or it's not getting a signal at all. I can't remember. But in any event, it wouldn't hurt to check the wiring for that. heh Sorry I can't help out with the tach.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
