Where is my O2 Censor at?
Old Nov 27, 2001 | 12:11 PM
DAHULK2000's Avatar
Hey guys, i'm new at this so bare with me. Where is the o2 sensor located? I heard that when the "check engine" light comes on this might be the problem. My engine light sometimes comes on. Usually when i'm driving for over 20min straight over 50 on the highway. Can the O2 Censor be the problem? Where is it located. Please be specific, i'm new at this. THanx for any info!
92 Firebird 305 TBI
K&N Open Air Element
K&N Crank Case Filter
Just a begginer, soon i will advance!
Old Nov 27, 2001 | 12:43 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Usually if the light comes on and goes back out again without resetting the computer,it is the O2 sensor.Yours should be on the driver's side exhaust manifold, under the #5 spark plug.PITA to get to,a little easier with the special notched socket.You can buy one or make your own by grinding a deep socket.Not sure what size.Maybe 18mm?
Can't remember.
Rich
Old Nov 27, 2001 | 03:03 PM
rezinn's Avatar
Its 7/8. To learn how to check to see what code it is look at the main page under FAQ.
DARKmj16
May 29, 2013 08:36 AM
Deaclen
Car Audio
Sep 28, 2006 06:48 PM
Thirdgen89GTA
Jan 6, 2005 09:29 AM
