Vortec block? stroked & .30 over
Old Nov 9, 2005 | 10:13 AM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
I have a motor that was bought at a speedshop and put in my old 89 formula. It has vortec heads, but could it have a vortec block. In my quest for stroking the motor, a diferent machiene shop guy said that if it was a vortec block scrap it and get one from a junkyard because they're too thin. Is this true? I plan on stroking it, ans boring it .30. someday hopefully even a little nitrous. What should i look for to see if i can do these things to my block?
Old Nov 9, 2005 | 12:38 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Some of the vortec blocks cannot be turned into strokers. The area under the bores is too thick with no extra meat to grind away. In short you cannot make connecting rod clearance in the block.
As far as the rest of the block goes, the vortec block is one of the best.
Old Nov 9, 2005 | 02:33 PM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
how would i tell if my block is vortec, and if it is, a strokeable vortec?
Old Nov 9, 2005 | 04:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Casting number.
69GTOby
Apr 18, 2016 02:34 PM
Jorlain
Oct 8, 2015 01:57 AM
BLK87Z
Sep 18, 2015 11:29 PM
Liveaction
Sep 17, 2015 06:29 PM
