How much HP u think?
Old Nov 27, 2001 | 12:22 PM
1986CamaroIROC-Z's Avatar
I would like to add the following mods to my car in the sig, and am trying to figure out how much power I would have.
Here are the mods:
-World Torquer 305's Pocket Ported
-Porting Plenum
-COmpcams 206/214 DUr@.05;.436/454 lift
-comp 1.5 roller rockers
-Edelbrock Headers
-Hooker Cat-back
Also, with this setup and 3.23 gears instead of the 2.73's, could I hit 13's u think?
1986 Metallic Blue IROC-Z
80k miles, 305 TPI
Mods:
-Edelbrock Hi-Flow baseplate
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Nov 27, 2001 | 12:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would think you would need 3:42s and a higher stall TC to hit 13s.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 27, 2001 | 04:09 PM
If i add March Underdrive Pulleys, and an ACcel Fuel Pressure Regulator, with a 1500 stall converter, then can I make 13's, and how much HP u think? Atleast 300?
80k miles, 305 TPI
Mods:
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Nov 27, 2001 | 04:11 PM
also, do u think I would need bigger injectors?
80k miles, 305 TPI
Mods:
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Nov 27, 2001 | 08:16 PM
Car: 99 Formula
Axle/Gears: 342
You want to pick a TC that has a stall speed 500rpm below your peak torque rpm, I believe. I'm not really sure how much power you would be putting out, I'll let that for someone else to answer.
Old Nov 27, 2001 | 10:10 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
You can go slightly higher with your cam and while you're at it why not go for 1.6 rockers?
You won't need bigger injectors either.
Rob
