do i need valve seats?
Old Nov 10, 2005 | 12:28 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
do i need spring cups?
im assembling a set of dart 200/64cc iron eagle platinum heads and had a quick question. The spring pocket is much bigger in diameter than my valve springs are, and i obviously need to shim them to get the 1.750 installed height. Is it ok for me to just set the valve springs on top of the shims and leave it or should i use a spring cup too since the pocket is so big it seems like the spring could shift around in there maybe but i dunno. Should i use a spring cup?
Old Nov 10, 2005 | 01:17 PM
ede's Avatar
ede
i think you have your terms mixed up. a valve seat goes under the head of the valve, on the cylinder side of the head. waht you want to say is a spring cup. i'd use one if it were me.
Old Nov 10, 2005 | 04:10 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
OOps, thats what i meant....durrrr. Man where was my mind today?
Hotrodboba400
Dec 10, 2019 07:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
