ok can someone tell me ..
Old Nov 10, 2005 | 05:38 PM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
i think these are the casting numbers on my block 14102182 the car got some ***** and peels out n chirps easy it feels like it can be a 350 i went on the mortec site n couldnt find ne thing so can any1 help me on this is it a 305 or 350??
Old Nov 10, 2005 | 09:22 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Most blocks have a 5.0 or 5.7 cast into them near the casting number. If numbers fail your investigative work you will need to pull a head and measure the bore.
Old Nov 10, 2005 | 10:29 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Sure you wrote it down correctly?
Dont tell me you misread the last number as a 2 instead of a 7. And if you did you should be slapped for reading the head casting number
14102187...87-91...305..........1.84"/1.5" valves
Old Nov 10, 2005 | 11:52 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Old Nov 11, 2005 | 03:37 PM
MoroteZ28's Avatar
hey it was night time i couldnt see that good but yeh thanks
