Car bucking and popping through exhaust
Old Nov 12, 2005 | 05:31 PM
project_91RS's Avatar
The car has a carbed 350 with vortec heads, 650Dp, and an xe268 camshaft. For a couple days it bucked at low speeds (about 5-15) and that was it. Then it started doing it at highway speeds too and later that same day it started popping through the exhaust during acceleration and idling very rough.
I changed the plug wires and it made it worse if anything. The plugs were changed about a week ago when i did the cam swap, the distributor is a remanufactured Mallory with a summit cap and coil thats about a month old.
To check if i was getting spark i connected the timing light and had very erratic spark on #1 at idle, usually none, but if i gave it a little gas it started sparking. I went through each wire doing that and found that to be the case with 3 or 4 of them.
I've checked the firing order about 10 times already and made sure the carb was adjusted correctly. I think its an ignition problem, but with basically a brand new ignition setup i really dont feel comfortable dumping money into it without knowing for sure. Any thoughts?
Old Nov 12, 2005 | 08:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
the bucking is usually wayyy too much timing.
or bad ignition, which is what it sounds like from your tests.
checked the wires are set for the firing order, good...
if you still have an old distributor, i'd try swapping that back on. I'm guessing it's in the internals of the dist, and if you have an old one (or a nice friend...), that'd be an easy (cheap) check..
Old Nov 12, 2005 | 10:22 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I agree, this sounds like a timing issue.
Old Nov 14, 2005 | 11:32 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Sounds like a bad ign module. They are supposed to be mounted using heat sink compound. If the compound is not used, the module will overheat and suffer an early death.
Also look inside the disp cap with a very bright light or direct sun light. If you see very narrow black lines inside the cap, replace it. Once a spark wonders off the beaten path, it leaves a trail (called carbon tracking) fused into the plastic. The next spark will be tempted to follow the same path and deposited more carbon, making the path even more attractive for the next spark, and so on.
Steven 86IROC-Z
May 24, 2026 04:52 AM
RazorN8
Jan 7, 2022 11:44 AM
TheExaminer
Aug 26, 2015 04:59 PM
