Need torque spec
Old Nov 14, 2005 | 12:06 PM
goose21's Avatar
Car: 85 Monte Carlo, 93 C1500, 98 Neon
Engine: 355, 4.3L, 2.0 DOHC
Transmission: T5, 4L60E, T350
Axle/Gears: 2.73, 3.42, 3.94
Need torque spec
I can't find the torque needed for the bolts that hold down the spider for a roller cammed 350. I searched this forum and found nothing. My Haynes manual does not list a torque spec.
I'm guessing the correct spec is around 30 Lb.*Ft.?
Old Nov 14, 2005 | 05:45 PM
ede's Avatar
ede
i'd guess more like 150 in/lbs. i'd just use a 1/4" ratchet and tighten it up and not worry about a spec.
Old Nov 14, 2005 | 08:11 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
PFT. Use blue loctite.
Old Nov 15, 2005 | 12:04 PM
goose21's Avatar
I ended up going with 20 Lb.Ft. or 240 Lb.In.
That's within the elastic range of a 5/16 grade 5 fastener.
I guess it really doesn't matter as long as it's tight.
Old Nov 15, 2005 | 01:13 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Definitely. I always clean the bolt & the holes with carb cleaner to get all the oil & crud off so the Loctite does it's job.
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
