smog
Old Nov 16, 2005 | 04:45 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
smog
my car was rejected and it is completely stock. can u tell me what i need to pass.
HC..........ppm: 33 [failed] needs to be at 100
CO..........%: 5.12 [failed] needs to be at 1.0
CO2........10.0 [passed]
O2...........3.3 [passed]
Old Nov 16, 2005 | 07:27 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
What computer chip are you using? Looking at your sig. your car is not stock.
Old Nov 16, 2005 | 07:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Kind of a dumb question but did you at least to a half *** tune-up on the car?
Old Nov 16, 2005 | 11:56 PM
dennine3003's Avatar
Car: 1985 Camaro RS
Engine: v-8 5.0 tbi
Is your EGR valve working ok????? If not replace it. 9 out of 10 times it's the EGR valve. or it could be the o2 senser. My best bet though would be the EGR valve.
Old Nov 17, 2005 | 12:13 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
i am talking about the car with 9k orignal miles not the white one that is all pumped up.
Old Nov 17, 2005 | 11:34 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
I dont get exactly why they said your hc's failed. If your at 33 thats less than 100. Which is good. Maybe its 133?
In either case Id say your cats not working properly. Theres plenty of oxygen for the hc's and co to react with in the cat, but it seems that thats not happening.
Old Nov 17, 2005 | 12:49 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Try ohming out the injectors to see if they are leaking.
Could also have one struggling to move any fuel.
Lean misfire will put fuel in the exhuast as well as easily as a driping injector.
Might prove wise to make sure everything ignition wise is ok and all vacuum lines are good as well.
later
Jeremy
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
