rebuild help
Transmission: 4L80E/4L80E
How much are you willing to do yourself? Pull the engine and take it to them, have them do all the work and then you reinstall? Or, disassemble it, have them do the machine and special tools required work, you reassemble? Do you want the heads rebuilt? Just a rering and bearing job? Or, new pistons as well? Or, rebore with oversized pistons?
I would imagine if you drove your car to the shop, had the whole thing gone through including heads and drove it home when it was done, you'd be looking at a cool 3 grand or more. If you settle for a simple rering/bearing job and do most of the work yourself, you're looking at a few hundred.
Where you fall between those bounds is up to you.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
3.8TransAM
Sep 27, 2015 08:37 PM
