What happens when no PVS Switch installed?
Old Nov 24, 2005 | 10:06 AM
HawkeyeGT's Avatar
Car: 1982 Chevrolet Camaro Z28,
Engine: 5,0l
Transmission: TH 350
Hi,
as you can see above, I wanna know, what happen when I drive without the PVS Switch?
How would I notice it?
Thx
Hawk
Old Nov 24, 2005 | 11:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
PVS switch?
Old Nov 24, 2005 | 11:41 AM
HawkeyeGT's Avatar
Engine: 5,0l
Ported Vacuum Switch. It's located near the thermostathousing. Got 2 vacuumlines on, one is EGR and the other is something for the carb. The switch goes into a cooling-fluid-channel in the manifold.
EGR I do not have. Removed it.
Old Nov 24, 2005 | 11:43 AM
sellmanb's Avatar
Car: '86 Berlinetta
I always thought it was TVS.
Old Nov 24, 2005 | 11:52 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, Thermal Vacuum Switch. It supplies vacuum to the EGR valve only after the coolant has warmed up. If you took off the EGR, you can lose the TVS.
Old Nov 24, 2005 | 02:31 PM
HawkeyeGT's Avatar
Engine: 5,0l
Oh TVS? Some guy told me it's PVS. But ok, still learning :-)
Is it only for the EGR? 'Cause of the two hoses...
That would be very good. Because, the hole is to wide for the TVS and so I can just use a plug to close it.
Hawk
Old Nov 24, 2005 | 02:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
PVS is probably the Pfnord term for it or something.
Caspar
Jun 19, 2016 11:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
toronto formula
Nov 10, 2015 06:17 AM
dcbsracing007
Aug 18, 2015 07:24 AM
86IROC112
Aug 17, 2015 02:00 PM
