Help with adjusting valve lash!
Old Nov 24, 2005 | 10:50 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Ok so i have my motor right now at TDC for #1 firing and #6 exhaust. So first i adjust a rocker till theres no play in the pushrod and then tighten the pushrod another 3/4 of a turn after 0 play is reached with the pushrod. And then after that i spin the pushrod till i feel drag and go another 3/4 of a turn on the nut? Is this correct or i'm i not understanding the write up.
Also i need help with which valves are the intake ones and which are the exhaust. And also the numbering on the engine cylinders. For instance what is 1, 2, 3, 4, 5, 6, 7, 8.
Thank you guys for all your time. I just need to know if the top information is correct, and what is what for the intake/exhaust valves and the engine cl numbers. later
Old Nov 24, 2005 | 11:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
ill try and find the little picture for it but
#1 cyl is the drivers side front
#2 cyl is passenger side front
#3 cyl is driver side 2nd jug back
and so on...
As for me i just tighten till 0 then use my old cut up valve covers to tighten till they stop chattering.
Edit:
Ok heres a quick little pic i made...
Old Nov 25, 2005 | 10:08 AM
Car: 2002 SS
Engine: Ls1
ok thank you,
and i found the valves on the heads go like this
EI IE EI IE
Old Nov 25, 2005 | 11:30 AM
Vader's Avatar
Personally, I think 3/4 turn preload is too much. I try to stay at 1/4 to 1/2 turn at the most to prevent lifter pump up and valve float at higher RPMs. As long as the lifter is somewhere within it's lash adjustment range, it will maintain correct lash and be quiet.
Old Nov 25, 2005 | 11:46 AM
Car: 2002 SS
Engine: Ls1
yea i just got done , i went with 1/2 turns after i felt drag on the pushrod. this is a hydrollic set up
Old Nov 25, 2005 | 12:27 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I do it with the engine running.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
