Help ASAP please
Old Nov 25, 2005 | 04:33 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Help ASAP please
Ok guys I got one bolt from the bottom of the heater core cover and the two on the right side towards the bottom and at the top corner towards the ECM.......well how many bolts are there? and I hope there isnt one on the very top horizontal surface. Whats the prob why wont it come off, I thought I got the hard to get bolt?
Old Nov 25, 2005 | 05:23 PM
Vader's Avatar
Yes, there is one more on top. You'll need a 7mm socket, ¼" ratchet, and about 10" of extension. Once that's out, you're home free. If you remove the larger (8mm) hex bolt from the lower right corner of the dash, you can flex the dash panel outward slightly to make a little more room for the ratchet and your hand. If that doesn't work for you, removing the upper dash pad and cover allows easier access to teh last screw. Removing the dash pad is not very difficult either - Just a handful of screws, the most difficult of which are in the defroster outlets.
http://www.autozone.com/servlet/UiBr...3d80163c9a.jsp
Old Nov 25, 2005 | 05:55 PM
Engine: LB9, LB9
Ok Will I need a 1/4 inch swivel piece to get at it right?
Old Nov 25, 2005 | 06:35 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
hehe...I just did mine today and posted tips on how to do it:
https://www.thirdgen.org/techbb2/sho...hreadid=333174
I removed the dash pad and a bunch of little screws, probably 7mm. I also removed the two 10mm bolts holding the dash to the right side of the firewall and also removed the ECM carrier. It's held in by 2 screws down at the bottom of the dash. After doing this, it's pretty easy. If you've never done this before, I urge you to check out the thread linked above because it may help save some time & aggrevation.
Old Nov 26, 2005 | 09:51 PM
Engine: LB9, LB9
Ok guys well its in and on reassemble I cant get that top screw back in. It feels pretty tight with only 3 screws in it. You think I will be fine without that last screw?
Old Nov 27, 2005 | 07:54 AM
Vader's Avatar
It may be fine. Without that extra screw, it may also begin to sag and create a gap over time, especially when exposed to heat. To me, it's worth a little extra effort to install all the fasteners.
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
