Fuel system problems....what a pain.....anybody else have this or know how to fix ?
Old Dec 4, 2001 | 11:06 PM
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
I drive an 88 with the LO3, the entire fuel system is stock and lately it has had problems. I took it to a mechanic and he said that it is a problem with all 1988 Corsica's, Berretta's, and some Camaro's. Mine unfortuneatly now has that problem. The mechanic looked at it and said it is an intermittent problem, meaning that it only happens every so often. If you ask me it is very often but he said he will not know what is wrong until something completely breaks or shuts down. Apparently I will know when that happens because my car will simply not run any longer. I know its not the computer but I am wondering if anyone else with an 88 or otherwise has had this problem? If so what was the problem and how much did it cost to be fixed or are you just driving around with it? How much am I looking at for a new fuel system? Any amount of money would be worth it to correct the problem and not have to deal with this pain. Just wanna say thanks for any help you can give me ahead of time.
Old Dec 4, 2001 | 11:09 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
It sounds like it could be a fuel pump that is going bad. I think in the LO3 its in the tank and not inline. You may be able to pull the tank and replace it. Next time you have the problem, leave the key in the on position and crawl under the car to see if you hear the pump going...
-=-Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Dec 5, 2001 | 02:16 PM
snakeskinner's Avatar
pump will only run a couple seconds when you turn the key on with the engine off so don't go by that. It could very well be a fuel pump problem though. I'm not sure if your car has a fuel pressure port or not. I know the truck doesn't but not sure on the car. if it does, next time it does, push the schrader valve in and see if you have fuel pressure. If it's really a problem, might be worth just buying a new pump and having it put in. If the car's very old, pumps probably short lived anyway.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
2000 Ducati 996 Monoposto
83 MSE #52
Old Dec 5, 2001 | 08:06 PM
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
Thanks guys. Forgot to mention the mechanic said it is something in the fuel relay system. Would it be worth it to pay for the Painless Electric Fuel Pump Relay and Wiring Harness? It's only 27 bucks from Jegs (local parts store dont know if you have heard of it) Maybe that would fix the problem or at least wouldnt hurt. Anybody else used or heard of Painless? Good buy or...???
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
