Piston identification
Old Nov 26, 2005 | 01:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've got a set of used pistons here, but I don't know who made them. They're flat-topped with 4 valve reliefs, compression height looks like they'd be for a 5.7" rod 383. The only markings on them are "600P" cast into them, but I can't find it in any of my catalogs.
I suspect they might be Sterling or TRW or one of the other Federal Mogul family members, probably cheap rebuilder pistons or something.
Anyone have any ideas?
Old Nov 26, 2005 | 02:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
http://www.flatlanderracing.com//str...v-350383c.html
Check part #6.
I thought the 600p was familar, it says H 600P, H for Hyper, but I think you're correct on the TRW
Old Nov 26, 2005 | 02:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah no H on mine, if that makes a difference. Probably hypereutectic, but I'm wondering what the recommended ring gaps would be on these things if I decided to use them for something.
Old Nov 27, 2005 | 01:21 PM
Damon's Avatar
If they are Speed Pro/TRW pistons they claim you can use standard ring gaps with their hypers (around .020). I wouldn't run them quite that tight myself, but that's their recommendation.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
