main cap orders
Old Nov 28, 2005 | 07:20 PM
midnightsun13's Avatar
main cap orders
ok guys i havnt posted here in a while due to the fact that ive got my sights set on a 94 z-28 but i got a problem...
a friend of mine is freshening up a 305 out of a 1990 camaro to put in his pickup truck. however, in the process of tearing the engine down he got the main caps mixed up so if you guys know the order in which the main caps go (by numbers stamped on them) that would be really cool
thanks in advance guys and gals
rob
Old Nov 28, 2005 | 07:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Hopefully they've been stamped 1, 2, 3, 4, 5 from front to back.
Old Nov 29, 2005 | 09:19 AM
Vader's Avatar
The rear should be really easy. If it's been stamped "5", the front should have been "1". If it's been stamped "1" (although I don't know why), the front would have been "5".
Old Nov 29, 2005 | 11:08 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you can't figure out the order, you might be able to experiment with a bore gauge and a lot of patience. There are 23 ways to incorrectly install the caps. You'd be luckier with a 4 bolt block though, there'd be only 5 wrong ways to do it.
If you don't have a bore gauge or patience, you can have the block and caps align honed.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
gixxer92
Sep 1, 2015 04:32 PM
