TPS not going over 4V and idle speed screw
Old Dec 6, 2001 | 08:01 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I'm trying to fine tune the IROC and I got close, but can't get it right. Car is 88 IROC 350 TPI (MAF)
I adjusted the TPS to .540V and when I moved the throttle to WOT, it hit 3.76V. I thought that maybe I could adjust the idle screw down, readjust the TPS to .540V and have a higher range to play with. Well, after fiddling with it all I got it as high as 3.94V but the car didn't have throttle response it once had .. .sort of dogged a little bit and if I held the throttle at 2000RPM it ran a bit rough.
So I adjusted the screw out a bit to open up the throttle plates a little and readjusted the TPS and it's still not quite right and now my WOT is 3.74V so I just packed up and went inside.
QUESTIONS:
What is the proper procedure in adjusting the TPS in conjunction with the idle speed screw? Gap of the throttle plate to throttle body at idle, etc.? Why won't this thing get over 4V?
IROC-Zone
'88 Camaro IROC-Z 350 TPI
"Yea, though I walk through the valley of rice,
I shall fear no Turbo; for Torque art with me."
- Cullan Hooley
Old Dec 6, 2001 | 08:24 PM
rezinn's Avatar
You're supposed to adjust the idle air control valve first, and once you get the desired rpm at idle you then adjust the throttle position sensor. Read up on adjustments on the main page, maybe it will help.
Old Dec 6, 2001 | 08:40 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Dumb me, forgot to mention that the IAC has already been cleaned and adjusted. I don't need to do it again right?
Old Dec 6, 2001 | 08:43 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
DOH! I did the remove, clean, adjust pintle and reinstall. i didn't do the other part. Okay, I'll do that again ... missed a few steps there.
Okay, any idea why this TPS won't top 4.0V?
Old Dec 6, 2001 | 08:50 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by Allan:
</font>
mine did the same thing. found out the trottle was hitting the clamp on the TB. rotated the clamp now 4.54v
mrrjjdh03@aol.com moderator at www.fl-thirdgen.org
Old Dec 6, 2001 | 08:53 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Clamp? What clamp? On the throttle side or where the TPS sits?
Old Dec 7, 2001 | 07:09 PM
mrr23's Avatar
Engine: 360 HSR
Clamp? What clamp? On the throttle side or where the TPS sits?</font>
the part of the clamp on the throttle arm side. where you tighten it. it'll be obvious. just turn the throttle by hand and see if it hits anything.also i had to bend the full throttle stop to finally achieve the 4.5 volts.
[This message has been edited by mrr23 (edited December 07, 2001).]
db057
Jan 10, 2020 08:55 PM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
