I dont know what my fuel injector # per hour rate is can you guys help??!!
Old Dec 1, 2005 | 03:32 PM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
Well when I bought my car it already came with aftermarket fuel injectors and I have no idea what there # per hour rating is. I am wondering if there is a way to figure this out, do you guys know of any way to figure out what kind of injectors I might have? Well thanks for taking a look.
Old Dec 1, 2005 | 05:39 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
There is no definate reliable way, except for removing them and shipping them to Rich @ Cruzinperformance.
If you "burned" your own Eprom chips, you might be able (by trial and error) zero in on a good estimate by good selective chooses for the fuel injector constant.
However, if your BLMs are close to 128, the the fuel injector constant in the Eprom chip should be close to the actual flow rate of the injectors.
Old Dec 1, 2005 | 10:53 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
well thanks for the input!! Ill let you know if I ever do find out what they are!!
Old Dec 2, 2005 | 05:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: I dont know what my fuel injector # per hour rate is can you guys help??!!
If you can get a picture of one and post it. Also see if there are any numbers on the injector, and post that. The Bosch injectors that F*ord uses are color coded. The standard Bosch and GM injectors (Rochester and Multec) have numbers on them. 9 times out of 10 that is enough to know what injectors are in the engine.
RBob.
Old Dec 3, 2005 | 04:52 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
ok ill post when i can, I will not be able to work on my car till later next week. So Ill take a pic when I do go out there. I dont know if this helps (dout it will) but the injectors a blue. Well thanks again you guys.
Old Dec 8, 2005 | 10:29 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
OK you guys I was able to work on my motor today and I finally looked at my fuel injectors. They are made by Ford and also on each injector it says DENSO. The number on the injectors are F55E-A2E. I don’t know if any one has these, or could help me identify what injectors I have. Thanks you guys.
customblackbird
Aug 15, 2021 10:16 PM
bryan623
Mar 22, 2021 06:43 PM
kyleb24
Aug 15, 2015 08:24 AM
Street Lethal
Aug 14, 2015 08:25 PM
Firechicken86
Aug 12, 2015 10:07 PM
