Cooling Fan
Old Dec 11, 2001 | 06:47 AM
89FirebirdUK's Avatar
Cooling Fan
On my 305 TBI, my cooling fan has stopped working. Can anybody tell me where the fan is ? Is this thing controlled by a relay ? What else would make the fan stop working ?
Also my car is using a lot of anti-freeze/summer coolant and I don't think there is any leaking. Is it using so much because the cooling fan is not working ?
Geoff
Old Dec 11, 2001 | 08:42 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The switch that activates the fan is on the passenger side cylinder head,screwed in between cyl 6 & cyl 8.The relay is between the brake master cylinder and the left front fender,on the firewall.
The coolant's gotta be going somewhere.Is the expansion tank still there?It should catch everything,and return it as it cools off.
If you got it way too hot, you may have a cracked head or blown head gasket.
-Rich-
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
