should there be a check valve
Old Dec 11, 2001 | 04:29 PM
silentneko's Avatar
hey guys,
my car takes like 1 min. to start in the morning, if I look at my see through fuel filter I can see as soon as I shut down the engine the fuel flies back down the line. should there be a check valve in there that stops the fuel from flowing backwards, or is there some thing else wrong here. its an 305 lg4 engine with a q-jet. thanks
neko
'87 trans am
car in the making
angelfire.com/fl2/neko
Old Dec 11, 2001 | 05:14 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
sounds like you have a leak
Old Dec 11, 2001 | 05:15 PM
silentneko's Avatar
I checked, no leaks. and I get great gas mileage to. just starts hard because of lack of fuel.
neko
'87 trans am
car in the making
Old Dec 11, 2001 | 06:06 PM
82camaro's Avatar
Car: 82 camaro SC
Even if the line all the way back to the tank is empty(not very likely since the fuel comes out of the top of the tank), it will only take a few seconds to reach the carb. Maybe the pump is getting weak?
Also, if the line is drained overnight your car should still start right up and run for a little while--the carb holds fuel in the fuel bowl for quite a while.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
[This message has been edited by 82camaro (edited December 11, 2001).]
Old Dec 11, 2001 | 06:09 PM
silentneko's Avatar
if the float in the carb it dead would it cause this to happen, I need to rebuild the carb.
neko
'87 trans am
car in the making
deracer
Apr 11, 2016 12:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
mike_c
Aug 27, 2015 04:32 PM
Out-Cast
Aug 17, 2015 10:57 AM
