305 replacement
Old Dec 12, 2005 | 10:27 AM
xunedeinx's Avatar
Car: 1991 firebird
Engine: V8 305
305 replacement
How hard will replacing a 305 w/ another 305 be?
i have my driveway, a cherry picker, and some jackstands.
What do i need to do to get the engine out w/o a lift? never done it before?
any help will be appreaceated, thank you.
Old Dec 12, 2005 | 11:26 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
You've got everything you need.
xunedeinx,
What exactly do you mean by a "Lift". A floor lift like you might find at a professional's garage is not at all necessary, it would probably be in the way more than it would be helpful.
Sounds like you have all the big stuff you need. Since you have those items, you likely have all the smaller hand tools you need as well.
We put the Z-28 up on jackstands to keep the car stable and to provide some extra room for the tranny. I pulled them seperate, but put them back as a complete unit.
Sincerely,
Old Dec 14, 2005 | 07:56 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'd skip the jackstands if it were me - might have trouble getting block to clear car if it's jacked up. When I swapped, I was glad I was as low as possible - we still had to manuver block to keep from damaging radiator and front end. The higher the block in the air, the more top-heavy the whole picker becomes, and the harder to roll away from the car.
There is one other thing your missing - a 350 block!
Old Dec 14, 2005 | 08:00 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Old Dec 14, 2005 | 11:24 PM
Car: 1982 - Z28
I'd skip the jackstands if it were me.......... to keep from damaging radiator
Camaronewbie,
[IMPO] I'd never pull the block without taking the extra 2 minutes to pull the radiator. You already have the hoses removed and have certainly removed the fan shroud? Why risk the radiator?
Kurt
Old Dec 20, 2005 | 06:13 PM
Car: 1992 RS
Engine: Carbed 350
Originally posted by kboehringer
Camaronewbie,
Kurt
Well, now that I think about it, I think I did remove my radiator. What I was thinking about more so was the front of the body. Oh - and the A/C condensor - I did leave it in IIRC. When I did mine, I remember it being all we (brother and I) could do to get the block out over the front end 'cause the picker only lifts so high. Of course, we had the tranny attached too.
But, in the end - might as well left the radiator in - while it was out, one of the kids knocked a hole in it anyways! Just as well, after a closer inspection, the tank was starting to crack anyway - so a new one was needed afterall.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
marcusaw
Aug 10, 2015 08:13 AM
