New alternator... What to choose?
Old Dec 19, 2005 | 03:42 AM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
Just got my camaro's engine rebuild completed (or so I thought) and got a nice enough day to take it out for a while. Got to my in-laws house to show off the new engine. When I got there I noticed my amp gauge was reading between 13 and 8 (closer to 8) with the car still running, I shut her down. When I went to restart the car she wouldn't crank over. The starter just sputtered a little then the battery died colmpletely (as in not even a dome light on).
Obviously if I'm getting some charge from the alternator, that should mean I'm just drawing too much power. I'm running an electric water pump, the cooling fan, a tach, and a high output coil in the distributor. Besides, I want a one wire alternator.
I don't no what the stock alternator amperage output is (tell me if you know). I was wondering if I should go with a 80 or 100 amp alternator. an 80 amp will save me almost $60 over the 100 amp, but I want to be able to run a stereo and all headlights at night.
Old Dec 19, 2005 | 03:48 AM
Vader's Avatar
It's also possible that the alternator is damaged and not able to generate full current.
FWIW, my stock alternator on the '86 is 108A.
Old Dec 19, 2005 | 09:04 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: New alternator... What to choose?
Or it could mean its dying, I've never personally seen an alternator just die- they alway seem to slowly put out less power. I believe I'm running a 105A stock replacement alternator.
Old Dec 19, 2005 | 12:11 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
So I should just try rebuilding it. What all is involved in a rebuild anyway?
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
Victor6
Aug 30, 2015 02:09 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
Scott 88 GTA
Aftermarket Product Review
Oct 30, 2000 12:34 PM
