84 z28 idle question
Old Dec 25, 2005 | 10:08 PM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
merry christmas all.... i have an 84 Z28 LG4 and here is what it does. after idling in drive for 2 min or so it will throw a code 45 which i know means rich. after driving and coming to a stop the rpms will also stumble a little. long story short i got the car for 800 bucks cause it was blowing black smoke and the owner didnt have a clue. i have adjusted the carb and no more smoke. just wondering could it be bad o2 or bad cat.....
thanks for any suggestions
Old Dec 25, 2005 | 11:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what carb?
what was adjusted on it?
what is code 45 exactly?
could be O2 or cat, need more info...
Old Dec 26, 2005 | 12:17 AM
ibwats's Avatar
Car: 1989 RS
Engine: 305 LO3
Transmission: auto
computer controlled quadrojet
code 45 o2 sensor reading rich
adjusted two screws at front of carb
rotten egg smell until i adjusted carb now not as bad
car has 49k miles on it
Old Dec 26, 2005 | 09:44 AM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
rotten eggs might = bad cat.........
Old Dec 26, 2005 | 01:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
yep, cat....
you could chop that and bolt in a "test pipe" temporarily, see if it fixes it...
if that doesn't help, you may need to adjust the mixture solenoid, or TPS as well.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
