1.6 Rr Too Much ?
Old Dec 28, 2005 | 01:08 AM
moneyman380's Avatar
Car: 1991 Z28
1.6 Rr Too Much ?
Wanted some opinions on wether or not i should use 1.6 roller rockers or 1.5's on my setup im putting together.
355 four bolt
all forged internals
dart pro aluminum heads
10.3 c\r
accel superram
comp cam 280XFI HR-13 Lift .576 .571 Dur 280 288 L.S. 113
Thinking about going with some comp cam 1.6 magnum roller rockers but worried it might be a little much.
Old Dec 28, 2005 | 01:18 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If your cylinder head flow will support it (i.e where does your peak cylinder head flow occur? At which lift?) and if you have the physical clearance, sure why not.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
