Torque specs
Old Dec 30, 2005 | 12:33 PM
cobrajet69's Avatar
Car: 88 IROC
Engine: ZZ4, Fast Burn Heads
Torque specs
Any one know what the torque specs and sequencing is for head bolts on a 385 fast burn head?
I've called EVERYONE (even googled it) and the only one that gave any info at all was Scoggin-Dickey and they said it was the same as the iron heads - 65 ft/lbs and the same sequence. I just want to corroborate that with someone else.
Thanks in advance.
David
Old Dec 30, 2005 | 12:52 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Torque specs
That's basically true, but the proper torque is going to be specified by your head-bolts. If you use stock bolts, then use the stock torque specs. If ARP, then they should tell you.
Old Dec 30, 2005 | 12:56 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
ARP is 60 with aluminum heads and their greese. Iron heads are 65 and their greese
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
