quick question about holley stealthram
Old Dec 30, 2005 | 02:31 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
I did do a search first and what I found didnt answer my questions. I am really interested in the Holley stealthram set-up and I'm wondering a few things. Do you need to have vortech heads to run this or can I put it on my stock engine with no problems? it says its good for 60 HP and If I can just bolt it on my stock engine I'm probably going to buy it. Thanks alot for the help!
Old Dec 30, 2005 | 02:37 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
you do not need vortec heads, it will bolt onto your stock setup..holley makes one for standard and vortec heads...just make sure you get the one for the standard sbc...also do a search on here for "stealtram fuel lines", you will need a new set of fuel lines..there are several ways to do it..just do a search..good luck
mike
Old Dec 30, 2005 | 09:50 PM
89TPI350's Avatar
Since I'm putting this on my stock engine I don't expect 60 HP at all, but will I still see a noticeable difference in power or is it not going to do much? And I was also wondering if I can use my stock throttle body until I can get a 58mm. Thanks
Old Dec 31, 2005 | 10:48 AM
89TPI350's Avatar
does anybody know if I can use the stock throttle body?
Old Dec 31, 2005 | 11:17 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
https://www.thirdgen.org/techbb2/sho...hreadid=114308
Old Dec 31, 2005 | 01:22 PM
89TPI350's Avatar
thanks alot great post
Old Dec 31, 2005 | 06:37 PM
grumpyvette's Avatar
http://www.gmhightechperformance.com...holleystealth/
you may want to read thru this
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
