hesitating
Old Jan 2, 2006 | 01:49 PM
gargoyle725's Avatar
hesitating
my 88 iroc just started to hesitate when i hit the gas.
i got a code of 54. is that my fuel pump going bad any help would be great.
thanx
Old Jan 2, 2006 | 02:24 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
54 <Fuel Injected models> <fuel pump relay> problems caused. defective fuel pump; defective fuel pump relay; defective oil pressure switch; poor electrical connection; open or short in circuit; defective ECM.
<from the 82-92> repair manual
Old Jan 2, 2006 | 02:59 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Got the following from the FAQ page. The link is on the left side of the home page:
Code 54. Low voltage at fuel pump OR
Low voltage at Fuel pump relay OR
Output failure at quad driver module
Time to get your voltmeter out.
Old Jan 2, 2006 | 03:18 PM
thank you
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
