more suggestion on this O2
Old Jan 2, 2006 | 11:30 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
sensor removal,i've soaked it with liquid wrench,numerous times,tried with engine warm,engine very warm,engine cold,I'm pretty sure it's the original and seems to have become 1 with the exhaust manifold,even got the deep socket tool,since the crowsfoot wasn't working,is it time to really put some torque to it?getting my propane torch up to heat the bung is difficult to get in there???after my trip I got @16mpg on highway,it shoots a 13 and 44 code,have @.5dcv from ecm and less than .250 from sensor warm,pretty sure the O2 is lazy or dead,the exhaust is very rich,is this the ecm widening injector pulse to compensate for to much air(lean low voltage from sensor)??really want to get this changed,and hope I've not ruined my cats
Old Jan 2, 2006 | 11:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
3' cheater bar on the end of a breaker bar. I have an iron pipe of that length for such purposes. Did my Caprice in a jiffy.
Old Jan 2, 2006 | 11:49 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
good enuf
will really put some torque to it then,just was worried after reading searches that talk of bung striping out etc......
Old Jan 3, 2006 | 01:00 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Do whatever it takes to get the sucker out!
Remember everything can be fixed, if you bust the bung weld a new one in
Old Jan 4, 2006 | 07:45 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Case of pop and a mechanic on a slow day.
You need oxy/ace and get it red hot, but you probably started to strip out the nut, sooo maybe just order a bung and remove the exhaust. Drill the hole and clean it up, a normal person with welder setup would take 1 minute to weld it on.
BTW, 84z nice REV, i just bought an 05' 500ss myself.
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
