Ignition Module Problems, Revisited
Old Jan 10, 2006 | 03:30 AM
Elusive R's Avatar
Car: 1970 El Camino
Engine: ZZ4 TPI Powercoated Black, SLP Runn
Transmission: LS1 T56, Moser 9" 3.25 Posi
I posted awhile back with an ignition problem where I was losing all timing control. I assumed that because my Accel Gen6 system was left on with the car off for over 10 hours that the timing circuits in the module had burned up from the system being left on. So, I bought a brand new GM module (the $80 one) yesterday and installed it tonight. Before I left, I checked the timing (cold start) and read 20 degrees at idle, which is exactly as programmed into my timing map. I got no more than 2 miles before the same symptoms showed up: low RPM stumble, violent bucking at some RPMs (generally ~1600-1800), and poor idle.
Once I got back, I checked the timing with the light, and sure enough - 10 degrees at idle, then the module pulls timing out to pretty much 0 degrees from about 1000 to 1400 RPM or so, then the timing starts to come back in before jumping back up at a (currently) unknown RPM. Has anyone seen this happen?
I'm running a Mallory VI-AL box and an Accel coil. I'm going the check it again in the morning to see if it is just a heat related problem, in which case I'll be mounting the module externally and with a fan. Any ideas???
Help!
Ryan
Old Jan 10, 2006 | 03:01 PM
Damon's Avatar
I'd be more inclined to think this is a problem with the aftermarket ignition box than with the factory module, if I had to take a guess.
Diagnostics: Disconnect the ignition box and run it just like stock for a while to see if the same problem still crops us. If it does, it's something in the factory electronics. If it doesn't it's the ignition box.
Old Jan 10, 2006 | 06:52 PM
Elusive R's Avatar
Car: 1970 El Camino
I think I may end up trying that. It ran the same this morning, so it's definitely not a heat issue. I'm concerned, though, that the module may already be bad if the box fried it, so I'd have to pick up yet another to try. Hopefully I can get one of the parts places to take one back or exchange it.
Thanks,
Ryan
Old Jan 12, 2006 | 10:19 AM
Elusive R's Avatar
Car: 1970 El Camino
So this morning, the car would not start with the GM module. Went back to the old cheap one and the car starts. Seems I got a dud from GM, which might explain the lack of timing control. I'll try the dealer and hopefully they can either refund my money or give me another one. What a mess...
Old Jan 12, 2006 | 06:03 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I keep blowing ignition modules in my car too! I've tried oem and aftermarket, and the oem lasts the longest.
Old Jan 13, 2006 | 06:43 AM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
modules
hey guys
if you keep having a problem with the car smoking ING modules check the Fuel Pump relay. i used to have a 88 TBI car and it went thru 2 modules and a pick-coil. and then one day i was driving the car and the check engine light came on and the code was Fuel pump voltage low. and it turned out the relay was bad and later on down the road 2-3 k miles later the Fuel pump went bad .
and i think the ECM checks Fuel pump voltage from the Dist.
Ghettobird52
Jul 5, 2024 11:18 PM
Bryan F
Aug 27, 2015 07:28 AM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
