Changine the right headlight blub, instructions?
Old Jan 13, 2006 | 12:06 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey I need to pick up a right bulb tomorrow and replace it on the 90 Formula. The brights work, but not the regular bulb. I did a search, and didn't have much luck.
Old Jan 15, 2006 | 02:18 PM
yzinger1's Avatar
Car: 1991 transam,gunmetal,t-tops,
Engine: 305,.030,k&n,airfoil,3inch exhaust,flowmaster80
Transmission: 700 r4
Axle/Gears: 4:10 posi unit
re:headlihgt
raise your hood beside the headlight is a **** ,turn the **** clockwise until the light comes all the way up,theres a cover around the light (plastic) in this cover is 4 star screws ,remove these 4 screws ,lay cover to the side.now, theres a metal piece around the bulb,theres phillips screws holding this piece on,IF you are really careful you only have to undo 2 of these,pull the metal piece slowly down over the bulb,pull the bulb straight out,theres a plug on the back pull this straight back until unplugged.install new bulb .hope this helps
Old Jan 15, 2006 | 04:48 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I changed the bulb, but I didn't turn the ****. I just turned the headlights on.
Old Jan 15, 2006 | 05:00 PM
yzinger1's Avatar
lights
hey man whatever works ,the main thing is you now have lights.this is a good thing.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
