85 IROC fuel pump replacement question
Old Jan 23, 2006 | 09:11 PM
MMC's Avatar
MMC
I have an 85 IROC 305 TPI and am going to replace the fuel pump in the tank .Can i get the job done just lowering the exhaust or do i need to drop the rear end also? Any tips from someone that has done it before?Thanks in advance
Old Jan 23, 2006 | 09:54 PM
TheNuge876's Avatar
Car: 1986 Trans Am
if you use the search feature theres probably a lot of info about it on this board. I think you have to take the rear out though to drop the tank.
Old Jan 23, 2006 | 09:59 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Don't have to take it completely out, but it's easier that way. Take the shocks off the rear and lower it with a jack. Pull the springs out too. That will get it low enough to snake the tank out. Make sure it's empty! It's a pain trying to snake the tank in/out with more than a splash of gas in it
Old Jan 23, 2006 | 10:02 PM
MMC's Avatar
MMC
Thanks i did a search after i posted and found out everything i needed to know.Sorry i posted a little to quick.
Old Jan 24, 2006 | 03:35 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Watch out for the rear brake line when you drop the rear-end down. I had to disconnect mine. No plug handy so all my fluid drained out. Then had to remove and bleed master cyl, bleeds the brakes, etc..
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
