what kind of pistons are these, and how much compression??
Old Jan 25, 2006 | 12:10 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok so im running trick flow twisted wedge heads 64cc milled t0 62cc, the pistons im running are in the pic below, the block is NOT decked, and im using a fel pro 1010 head gasket.
im just wondering if someone can tell me what kind of pistons these are, and how much compression im making.
Old Jan 25, 2006 | 12:56 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
They look like standard 5cc valve relief flat tops. If they are you should expect about 9.95:1 compression with the 1010 head gasket, and assuming the piston is sitting 0.025 in the hole, with a 1.56 compression height, combined with a 62cc head, a 5.7 rod, and a standard crank.
Piston similarity: http://store.summitracing.com/defaul...9&autoview=sku
Old Jan 25, 2006 | 02:43 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
sweet i was hoping for a roughly 10:1 compress
Old Jan 25, 2006 | 04:53 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
TRW or Seald power trw # 2256
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
