Few questions on tuning
Old Feb 3, 2006 | 02:37 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
I want my car to run up to its full potential next time I take it up to the track. What should I check before I go? Sparkplugs,and so Thanks
Old Feb 3, 2006 | 03:00 PM
slapi01's Avatar
Car: trans am
Engine: sbc350, afr 180cc head, comp full roller, xtrem 276,comp 1.6 roller rockers,weiand142
Transmission: tremec tko
Axle/Gears: 8.5 3.73 gear, moser 30 spline axles,eaton posi
one of the most underrated things people don't do is change the oil before they go and after. i do this everytime i ran any of my cars at the track. plugs, timing, air pressure -tires and air filter for just a few...
Old Feb 3, 2006 | 03:03 PM
Car: ws6
Engine: ls1
Transmission: m6
Cool, thanks for the response. Can anyone else think of anything?
Old Feb 4, 2006 | 05:25 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Throw a block of dry ice over your manifold That would add you a few ponys.
Old Feb 4, 2006 | 05:31 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Some of my rituals include:
Changing plugs/adding a little gap
Adding some ignition timing
Air front tires up to 40-45 psi, lower backs down to 20-25 psi, depending on the tires
If the air filter is dirty, run without it
Clean the TB
Check the rotor and cap terminals, file them clean
Verify/adjust fuel pressure (those with an AFPR)
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
