Smog Pump..
Old Feb 9, 2006 | 01:07 AM
purg3d's Avatar
Car: '92 RS
Smog Pump..
In operation, the pully doesnt spin smoothly. I hear somewhat of a grinding sound coming from it while running, and also while manually turning it.
What's the diagnosis, doc? Is it on its way to seizure, or already there? And should I be considering removing it, until I can afford to get a replacement?
Also, has anyone tried using the stock belt with the rerouting configuration w/out a smog pully? serpentine setup.
Old Feb 9, 2006 | 10:48 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
It's time to replace it.
You can remove it and reroute the belt. However, you need to get a longer belt. There is a tech article on removing the smog with a pic of how to reroute it and belt length.
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
