Steering wheel off a bit
Old Feb 18, 2006 | 11:05 AM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
My steering tires are straight, but my steering wheel is about 1/8 of a turn to the left. what do I got to do to get them lined up?
Old Feb 18, 2006 | 11:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Get the tires straight. Remove the steering wheel (you'll need a puller) and reposition the steering wheel so that it lines up as you wish.
JamesC
Old Feb 19, 2006 | 07:57 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
did you do any alignment work on your car in the past or anything like pull the wheel off where im getting at is if your steering wheel was straight and now its off i would get the steering and suspension looked at something could be wrong its always safe to see why its off then to just repair it quickly
Old Feb 20, 2006 | 07:52 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
The only way to fix that is to take it to an alignment shop. The steering wheel on mine is the same, but I like it there because I can see the guages better. I can't change it myself anyway, because the steering wheel is indexed to the column by way of the Horn contact hole, and I'm sure yours is the same.
Old Feb 20, 2006 | 07:58 AM
JamesC's Avatar
I yanked the stocker with a puller and stuck on the after market. Simple and straightforward.
JamesC
Old Feb 20, 2006 | 08:08 AM
Zed'er's Avatar
Car: 84 Z28HO
I had an aftermarket on there as well, a Grant three spoke. The adapter still indexed with the horn contact hole, and it was still crooked, because the three bolts holding it on are not spaced equally (meaning it can only go on one way). Maybe your adapter is different.
Old Feb 20, 2006 | 08:11 AM
JamesC's Avatar
Strange. I have a Grant Collector's edition. No problem.
JamesC
Jorlain
Aug 24, 2022 05:11 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
