L98 con/main bearings
Old Feb 26, 2006 | 12:48 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
hey guys i will hopefully be getting a low mile l98 long block in the next few weeks and seeing as im on a budget and the engine is low mile i was just gonna leakdown it to determine top end condition and replace the main and conrod bearings assuming there are no spun or gouged. which federal mogul series is good for this application max horsepower will be 375-400 and no more than 5500 rpm mostly just a cruiser with the ocassional strip visit, thanks i tried serching but figured i would just flat out ask thanks again guys engine has approx 60-70 k on it
Old Feb 26, 2006 | 12:50 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
ACL bearings are where it's at. Polish and mic the crank while it's apart to make sure it doesn't need a grind and be sure to check the clearances before you put it together.
Old Feb 26, 2006 | 02:53 PM
1984HO's Avatar
Car: 1984 Z28
when you say polish is that something i can do or a machine shop must do? checking clearences is someting i planned on anyways
Old Feb 26, 2006 | 03:12 PM
Dialed_In's Avatar
something a machine should do. You chuck the crank in a lathe and use different abrasive belts to polish the journals and get rid of any slight imperfections.
It should run you about $80 for them to clean and mag the crank to make sure it isn't cracked, check it for straight, mic the journals and them polish it.
Old Feb 26, 2006 | 03:25 PM
1984HO's Avatar
Car: 1984 Z28
awesome thanks dialedin also where cam i get acl bearings??
Old Feb 26, 2006 | 03:40 PM
Dialed_In's Avatar
I may have some in stock.
FormulasOnly
Jul 23, 2018 08:47 AM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
