roller block with flat lifters
Old Mar 3, 2006 | 08:10 AM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
trust me i've searched, and i didn't want to look like a retard, but can you use flat lifters pre-87 on a roller block 87-newer???
and while i'm at it, what does HEI stand for
Old Mar 3, 2006 | 09:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, as long as the cam is intended for flat tappets. And, you'll need longer pushrods, as the roller lifters are taller than flat tappets.
High Energy Ignition.
(This is more of a Tech topic than Engine Swap, so I'll move it over there.)
Old Mar 3, 2006 | 12:54 PM
Damon's Avatar
Works just fine. Done it many times myself. The flat tappet lifter looks a little funny sitting WAY down in the lifter bore but it works just fine. Yes, you must use flat-tappet length pushrods (7.80" is stock).
Also, you must use a flat tappet style timing chain and remove the factory roller cam retaining plate from the front of the block.
The Camaro in my sig, below is running a flat tappet in a roller cam block right now.
Old Mar 3, 2006 | 02:39 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
You should check for timing chain to block interference, just above the 3 oil galley plugs when running a double roller in a factory roller block. My $20 special cloyes double roller clearanced the block for me in a previous engine (found out 50k miles later-no harm no foul).
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
dimented24x7
Sep 6, 2015 03:51 PM
