Checking comperssion on "suspect" cylinders
Old Mar 13, 2006 | 06:55 PM
shawntmartin's Avatar
Engine: ZZ4
Transmission: TH-350
Axle/Gears: 3:73
I have 2 plugs that are wet, black, and oily. The rest are perfectly chocolate brown. Car runs great, no smoke anytime. But, I'd like to check my rings (compression). What is the cheapest (and still accurate) method? Advance Auto, Napa, or Autozone have something for sale?
Old Mar 13, 2006 | 07:11 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Any autoparts store should have a compression tester either for sale or rent, you can pick them up fairly cheap just to have one in the toolbox...
If you do find low compression in the cylinders try squirting a bit of oil down that cylinder. If the compression jumps up you have a ring problem, if it stays the same you have a valve not seating or possibly both.
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
