7qt oil pan...
Old Mar 21, 2006 | 03:48 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
7qt oil pan...
Since search function is down, i was unable to search this.
I am wondering what would i have to look for when i buy a higher capacity oil pan?
I have a high volume pump, and high pressure spring, i will need a higher volume pan, i know this.
But the ones i see, are all different in many ways.
What would i have to look for, in order to clear k-member, and exhaust?
Old Mar 22, 2006 | 10:19 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
bump.......
Old Mar 22, 2006 | 09:47 PM
Untamed Z's Avatar
I bought a Moroso pan last fall and researched prior to buying. I think the largest capacity you can go is a 6 qt. pan w/o running into clearance issues. It is listed in Jegs and Summit, But I'd price check the two before ordering. I priced injectors a few days ago and Jeg's was $80 higher a set. Hope this helps.
Old Mar 23, 2006 | 02:11 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I run the Moroso pan also.
Make sure u get the pan and the extended sump pickup when u order and braze it on.
Expect to kiss your current y-pipe goodbye. U will be cutting it or making a new one :-) It will clear the crossmember fine however.
later
Jeremy
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
