MSD or CRANE HI-6?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
MSD or CRANE HI-6?
What do you prefer and why? I'm trying to choose one or the other. My car is just for street use. Nothing competitive. It's a 1987 GTA 5.7. Bored .020 a mild cam and headers. Nothing to crazy.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I suggest stock. Reasoning is because that car wont notice a differance. Get into a power adder or high compression, then you may want to think about it.
Car: Formula
Engine: 6.0 LSX
I would upgrade the coil to an MSD unit or something, Replace the pick-up coil inside the distributor and check the ignition module. With that done, get a good brass cap and rotor, some good wires and AC plugs. You should be all good to go then.
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
