starter/flexplate
Old Mar 23, 2006 | 03:01 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
starter/flexplate
Ok i had baught a brand new starter for my camaro with a 153 teeth flexplate for a 1 peice seal but the engine spun a bearing and im replacing with a 355 with a 2 peice seal. i need to know what cars came with a 168 tooth flexplate beacuse i baught a flexplate on ebay the guy said it was 153 but wasent so im going to just exchange the starter for a new one. but need to know what cars or trucks came with a 168 teeth flexplate with a 2 peice seal. thanks
Old Mar 23, 2006 | 05:18 PM
Just about everything from the mid 60s to the late 80s. Virtually all Turbo 350 and 400 applications (small-block and big-block V8s) for example, both car and truck.
Why are you concerned about that? You're going about it backwars. What's wrong with putting a 12.8" flex plate for a 2-piece RMS motor in your car? Just do it right and be done with it; sell that other flex plate on eBay and put it behind you.
Old Mar 24, 2006 | 08:17 PM
Car: 1987 iroc z
the 153 tooth one i took off the old motor wont fit the 2 peice seal. beacuse the hole in the middle is bigger for the 2 peice. and the one i baught off ebay the guy lied and said it was 153 but was a 168. so eaither i get a 153 tooth for a 2 peice seal or get a new starter for the 168 tooth.
Old Mar 24, 2006 | 09:17 PM
Right, your old one is for a 1-piece motor. You just need the 12.8" one for a 2-piece motor.
Look up the one for 83-85 Camaro/firebird V8 auto. It's the one you need. You can probably pick one up at AutoZone in the morning.
Old Mar 26, 2006 | 12:53 AM
Car: 1987 iroc z
the problem is the motors already in the car with the 168 could you tell me an exact car that came with the 168 so i can just exchange the starter i have for the one i need thanks.
Old Mar 26, 2006 | 09:08 AM
chesterfield's Avatar
Car: Pontiac
4.3 litre astrovan. uses the same starter as 168 tooth sbc.I'd guess 1988 would do it. make sure it has a staggered pattern. like this:
http://www.sallee-chevrolet.com/Star...s/01876555.jpg
"GM 01876552 Starter SBC & V6/90° Starter - Remanufactured, 14” flywheel."
come to think of it, you'd better check that your block has the staggered bolt holes. I'm not sure if it would or not. if it only has straight , then you're stuck buying an expensive aftermarket starter. one more thing i'd suggest is to make sure the flexplate didn't come off a 400cid.
