valves are out, how to clean them
Old Mar 24, 2006 | 10:43 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
so im rebuilding my heads, i got the valves out and they have alot of carbon build up.. Is it okay if i hit the valves up with a wire brush? i dont want to nick them up or anything. MAybe parts cleaner? or is it okay if i hit it with a wire brush.
Old Mar 24, 2006 | 11:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Wire wheel
Old Mar 25, 2006 | 01:21 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
wire brush chucked into a cordless drill works well for me.
Old Mar 25, 2006 | 11:40 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I chucked mine into a drill press, and used sandpaper. Back cut them a bit. chamfered the front face of the intakes, radiused the front face of the exhaust valves, and backcut them both. then finished with scotchbrite, then autosol polish.
if you're interested in the mods over just cleaning them, search for the thread I posted in with this info, "modifying valves" or something like that.
Old Mar 25, 2006 | 01:55 PM
xpndbl3's Avatar
Car: 1984 Z28
unfortunately the search is down, but when it gets back up I'll definately have to check it out. Thanks.
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
Victor6
Aug 30, 2015 02:09 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
