what kind of diff
Old Mar 26, 2006 | 10:15 PM
TREK's Avatar
Car: 1979 vette
Transmission: th350
what kind of diff
are there any numbers stamped or any way to tell what kind of car a differental assy came out of. i would use search but.
Old Mar 26, 2006 | 11:49 PM
Vader's Avatar
MAny rear axles have a stamped steel tag bolted to the rear cover, and/or numbers stamped on the front of the right axle housing tube.
Old Mar 27, 2006 | 09:44 AM
TREK's Avatar
Car: 1979 vette
Transmission: th350
i saw some numbers stamped on it. i wrote them down but cant find them. they where 8-9 digits and started with 2 and had GM in front of them. also saw a 5 digit number starting with a 1.
Old Mar 27, 2006 | 10:14 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The only problem with using the tag or RPO codes is that only tells you what was in the car when it rolled off the assembly line 20 years ago, not what it may have in it today!
Sounds like the casting number for the main center section housing piece; and a date code.
Pretty much useless.
If you want to know what a rear end is, besides what you can tell from the outside (brackets, length, etc.), the ONLY ACCURATE WAY to know, is to take off the cover and look inside.
Numbah-1
Oct 2, 2015 08:27 AM
Vincent135
Sep 28, 2015 10:50 PM
