305 w/ big cam
Old Mar 27, 2006 | 06:14 PM
Naphead's Avatar
305 w/ big cam
I have an performer rpm edelbrock cam sitting next to me and was wondering how it would do w/ a 305 lg4(w/ headers-performer intake-hotter coil) I even have matched springs, timing chain and all that good stuff. I do like the specs of this cam alot but is it too much? EDL-7102 on summit
Or do I put it in the pile of buildups for the 1970 350lt1 motor in the shed...
Thanks 4 the input.
Old Mar 27, 2006 | 06:57 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It would only work if you shaved the heads to the max and decked the block to get the compression ratio up 10:1+++. Then fully ported the 305 heads and installed larger 1.94x 1.50" valves. You would want a 4.56:1 or more rear gear and a 4000-4500stall converter (8" "race" for a 305)
You'll need lots of valve spring pressure as the 305 will make peak hp at over 7000rpm . You'd be much better off with a solid mechanical cam at this point as a 305 built like this will want to rev, but that is the general build plan to make that cam work in a 305.
Old Mar 27, 2006 | 07:22 PM
Naphead's Avatar
what kinda output would the 305 make? I think I have a set of double bump heads, will swapin those help? thanks!
Old Mar 27, 2006 | 09:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What he is really saying is that it's not a good cam. It is old school technology and almost absolutely worthless today. A modern cam grind will work much better.
Old Mar 28, 2006 | 01:51 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Essentially agreed. Especially if this is a street engine. I have a similarly aggressive engine (powerband-wise), and it does NOT do the street well at all.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
slowsi
Oct 18, 2015 08:49 PM
tommy z-28
Oct 6, 2015 10:58 PM
