Can I remove head w/o removing PS pulley and pump?
Old Mar 28, 2006 | 12:09 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I am currently dismantling my engine to change my head & intake gaskets. I have run into a snag. The power steering pump. It requires that I get a puller to remove the pulley. However, is the bracket attached to the head fully? Meaning couldn't I just remove the head and skip removing the PS pulley and pump?
Old Mar 28, 2006 | 12:41 AM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
You shouldnt need to take the pulley off, to unbolt the pump.
Old Mar 28, 2006 | 12:47 AM
Formula350Scott's Avatar
Unbolt the whole bracket for the alt and ps pump. Its easier.
Old Mar 28, 2006 | 07:15 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You do need to take the pulley off to unbolt the pump from the bracket; however, as was stated above, you can unbolt the whole bracket from the engine without removing the pulley...
Old Mar 28, 2006 | 07:34 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Unbolt the whole bracket and side it over to the side with some support to keep the PS lines from stretching.
later
Jeremy
Old Mar 28, 2006 | 08:13 AM
Car: 1994 Trans Am
The only bolt that I can see that's still holding the bracket on is inside behind the pump. It's a 45 or 50HEX thing. How many bolts hold on the bracket. I believe I have removed 3 so far.
Old Mar 28, 2006 | 08:48 AM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Get a torch, it makes things alot easier.. No wrenches needed
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
